Am2 exam help | on ElectriciansForums
Discuss Am2 exam help in the UK Electrical Forum area at ElectriciansForums.net
Northwest
Hi there my name is Adam and I have my am2 at the end of June an I'm bricking it lol.
Thought i would start this thread to see if any one has got any advice for the exam would be great.
i feel confident in most parts of the install apart from the lighting, heating system and embarrassingly the bonding as I haven't really done any and also the fault finding. With the lighting circuit there seems to be differing opinions on how it should be done does the spec change from test centre to test centre or same for all candidates? And finally what should I be revising for the online assessment.
thanks for reading any help would be gratefully appreciated
regards
adam glover
First of all before you start the practical exam make sure the install is locked off with a padlock and you TAKE THE KEY WITH YOU. Not doing that and you will fail before you start. Otherwise just practice over and over the bits you aren't so sure on and make sure you're confident with the wiring and you'll be fine. I found it quite easy for time when I did mine and I'm sure you get longer now as well.
Fault finding was a doddle as well, they give you a whole selection of testers you can use but I found every fault just using a bell tester.
the 2 way and inter switch must be connected from the switch below the light.so live from cu to L1 live from light L2 connect N in waggo.3 core then to connect to inter/switch then 3 core to final switch.remember to connect common at inter/switch to waggo then fix to common at last 2 way..
you have a 2 way to the left of the board then the inter then the second 2 way on the far left as you look at your bay.the light is above this switch.also remember you have a data point in-between the first 2way and the inter, don't use this as your switches.
Reply to Am2 exam help in the UK Electrical Forum area at ElectriciansForums.net
The video's are an accompaniment to the Book and referenced throughout.
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
