AM2 | Page 6 | on ElectriciansForums
Discuss AM2 in the The Welcome Forum area at ElectriciansForums.net
Wondering is the S plan wiring does it come with the diagram or have to memorise the diagram that Jamchiv01 had posted.
The CAT 5 have come into contact with through cabling and then the electrician's doing coms terminate it.
Assessment is near just trying to watch YouTube for visual practise..
Thanks loads for the help
You get the s plan wiring diagram given to you in the exam mate
Which cable size using on the S plan wiring....1.0mill and climping tool to be used...
What's the colour coding when terminating CAT 5..which colour comes first..
Hello, you will most likely use 1mm squared Heat resistant flex
What do you mean by crimping tool to be used? The conductors usually terminate into terminal block in the wiring center.
CAT 5 should be wired using one of the 2 standards. Best to stick with what's on the back of the faceplate you are using, just make sure that they both match.
Hope this helps.
Got s plan heater system to wire tomorrow. But am stuck which cable should you use from the distribution board to the thermal start switch and from the thermal start switch to the junction box....
I failed on test and inspection. Live test was a nightmare for me as I haven't done it in the site. So I have booked for a day training on test and inspection.
Reply to AM2 in the The Welcome Forum area at ElectriciansForums.net
Hi My first post here, so apologies for any mistakes. I think it will be DIY job with electrician sign off if required, but would like to do as...
L
Electrician UK Electrician looking to move to Australia 2025 UK Electrician looking to move to Australia 2025 Hi Everyone Looking for some...
lewish121
L
