Wondering is the S plan wiring does it come with the diagram or have to memorise the diagram that Jamchiv01 had posted.
The CAT 5 have come into contact with through cabling and then the electrician's doing coms terminate it.
Assessment is near just trying to watch YouTube for visual practise..
Thanks loads for the help
You get the s plan wiring diagram given to you in the exam mate
Which cable size using on the S plan wiring....1.0mill and climping tool to be used...
What's the colour coding when terminating CAT 5..which colour comes first..
Hello, you will most likely use 1mm squared Heat resistant flex
What do you mean by crimping tool to be used? The conductors usually terminate into terminal block in the wiring center.
CAT 5 should be wired using one of the 2 standards. Best to stick with what's on the back of the faceplate you are using, just make sure that they both match.
Hope this helps.
Got s plan heater system to wire tomorrow. But am stuck which cable should you use from the distribution board to the thermal start switch and from the thermal start switch to the junction box....
I failed on test and inspection. Live test was a nightmare for me as I haven't done it in the site. So I have booked for a day training on test and inspection.
Sorry to hear that it did not go so well.
At least you have good future plans in place.
I hope the training goes well and allows you to progress better next time.
C
Carlos_UK
C
Matthew terry,
mambo,
