American FF tripping RCD | on ElectriciansForums
Discuss American FF tripping RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
glasgow
hi I have a customer with an American Fridge freezer that trips the RCD every couple of hours. The FF is a couple of years old and cost ÂŁ2000 apparently , so the customer says replacing it is out of the question. Obviously all domestic circuits are to be RCD protected but is there a get out with a risk assessment to take that circuit off the RCD? It is not a dedicated circuit as it is the kitchen ring. Any advice would be great.
Cheers
Risk assessment is not permitted in domestic.
If the customer refuses to repair or replace then tough -------, that's their decision.
Beat me to it ruston.
I have a little earth leakage clamp meter set it to min max and leave it on suspect appliance.
You are stuffed without test gear , is it when the fridge or the freezer is cutting that is tripping it ? long shot that it is noticed I know
could you install a non-RCD dedicated circuit and fir a FCU?
Here Tel, borrow my Tin hat!
No he is right , as long as the circuit does not require an RCD because of installation methods.
I was going to suggest that if it was only high earth leakage that is causing the problem
Apparently in this model every now and then a heating element comes on to defrost the coil when needed and it is common to develop more earth leakage than an 30ma rcd will take. If it can't go on a non rcd circuit then there fooked by the looks of it
Reply to American FF tripping RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
