American FF tripping RCD | Page 3 | on ElectriciansForums
Discuss American FF tripping RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It will record either min or max for as long as the supply is on.
When supply is off(trips) it stops recording data but will leave you with a reading.
I have a mock up adaptor I use to separate L N E in the appliance flex as clamping the flex as a whole will give no reading.
I was without one until a year ago it really does save alot of agro.
Thanks!!
Hi - if the fridge was mine and given its age I'd have it repaired by manufacturer. Failing that I'd be disconnecting and testing the defrost heater as has been mentioned. I would not work to remove an RCD to solve an appliance trip, just saying.
This just has to be the best option.
The money they have already wasted for your time could have been used to get it repaired..
Just a thought: If it was bought with a US plug on the cord, (and assuming it is 220-240V machine), which has been chopped off and replaced by a UK plug, you might want to check the polarity of the connection to confirm that the switching (ie for thermostats, door light, compressor start coil, defrost heater) are in the line rather than the neutral.
might be worth measuring the baseline earth leakage on the circuit and then ramp testing the RCDs.
Could be oversensitive RCD coupled with a high baseline earth leakage on the circuits.
If its a big fancy Dan place, do they have loads of they USB charger sockets, PCs and the usual suspects.
The fridge may be performing as it always has but more 'leaky' accessories and appliances have been added.
long shot, but you never know.
He hasn't got an earth leakage clamp meter .
Reply to American FF tripping RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
