Could anyone give me a link or tell me were to get an analog voltage tester?
Just want to be prepared for phantom voltage!
Cheers all :smile5:
Cheers all :smile5:
Discuss Analog voltage tester? in the UK Electrical Forum area at ElectriciansForums.net
Spot onyou'd put the resistor in parallel with the leads. that would then drain phantom voltage that the dmm won't.
I'd love to believe this. The input impedance of my Martindale isn't quoted, but the manual says, "Test current: <3.5mA at 600V" which implies an input impedance of at least 170k. Not the 1M (or even 10M) of a DMM, but pretty close. The Drummond also pulls "<3.5mA" unless you press the button, in which case it will draw "28mA @ 240V AC, 60mA @ 500V AC."... Zin ~ 8k. Fluke's Lo-Z function is "about 3k" (according to Fluke literature).Any approved voltage indicator (AVI) should differentiate between a ghost and a real voltage.
Also, I have a Dilog voltage indicator, it bleeps and warbles and lights up like a Christmas tree when touching anything conductive vaguely close to something that might be energised. (Which is why I bought the Martindale).
So, although not doubting what you say, I am left a little confused!
Yep, that's the chicken. (Well, combivolt twos...)Which dilog AVI are you using? I have always used the combivolt ones
Well that's me told. Guess I've got some more learning to do.As with any test equipment you have to learn to use it correctly and how to interpret the readings.
Reply to Analog voltage tester? in the UK Electrical Forum area at ElectriciansForums.net
