Angle Grinder dust extraction.. | on ElectriciansForums
Discuss Angle Grinder dust extraction.. in the UK Electrical Forum area at ElectriciansForums.net
Looks like it's for use with the special cup wheels for surface grinding of concrete. May not be suitable for your purpose?
Ive been kinda looking at it wondering that...doesnt look as though the blade comes out for side cuts does it ?
reading further through that listing it says it has a removable part so maybe it would work ..would certainly be handy.
Have you thought about getting a proper chasing tool? I have one from machine mart and it works perfectly! I can chase from ceiling to floor in an ocupied house with hardly any dust when im finished
I have hilti wall chaser , but its only good for long chases , no good for boxes etc . I like grinder at switches etc as it can be done well and need no plaster round box. Ive just ordered a new 5" grinder. Need blades for the wall chaser don't know what to buy though hilti ones are really expensive, wondering if standard blades will do the job.
edit- also ordered extra long 5m hose for using henry and chaser. Hilti is pretty heavy and its chases aren't quite wide enough for capping in one pass.
i bought a couple from a 'tool sale' that used to be held locally and they were ok. worth a punt for a few ÂŁs. gaffer uses (or rather has!) twin chaser, and yes, has to be ran twice to get width for sheathing (sorry capping). best thing i think, if money permits, is vac with self cleaning filters- saves banging that henry dust filter out every 5mins when bags not used
Reply to Angle Grinder dust extraction.. in the UK Electrical Forum area at ElectriciansForums.net
C
Concrete subfloor leveling issue Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and instead of using...
Cat213
C
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
