another wet pants strikes again. | Page 2 | on ElectriciansForums
Discuss another wet pants strikes again. in the UK Electrical Forum area at ElectriciansForums.net
buzzlightyear
Nearly Esteemed
star command
called to a job to day where a customer says their emersion heater not working ,gets to the job ,open the cupboard and a nice unvented cylinder .
now this unvented cylinder has not one but two elements feed from a 2.5 cable the old emersion switch ,but wait on why is there two 3kw on..
now 3X2=6kw , the fuse had blown now ,this system wet pants have put in is a pressurised system ,their is no gas but water feed . now a nice new 6mm feed for both elements .and top it all the gas &water needs bonding has well.
[ElectriciansForums.net] another wet pants strikes again.
There should be a minimum of 300mm between the tundish and bend/elbow, The combination valve looks like it’s connected wrong and condensate pipe has been used for the discharge pipe. I would get the plumber back....looks like a DIY install.
Report it to Building Control. Notifiable works.
Reply to another wet pants strikes again. in the UK Electrical Forum area at ElectriciansForums.net
