Antique Chandalier - with no earth... | Page 2 | on ElectriciansForums
Discuss Antique Chandalier - with no earth... in the UK Electrical Forum area at ElectriciansForums.net
Sheffield
[ElectriciansForums.net] Antique Chandalier - with no earth...
Hi all. So I have been asked to install a couple of 18th century antique chandeliers that have previously been ‘electrified’ (customers words!).
Anyway I am but uneasy about it in terms of earthing. There is the kind of 2 core cable you sometimes get with modern double insulated pendants lights, and the cable feeds plastic e27 lamp holders around the chandelier. The cable is tied to the metal frame with thin tie wire.
Physical check and all is fine. I would have preferred to get an earth down to the frame - but can’t.
Obviously no double insulation symbol.
Am I being over-cautious? Would you put it up as is?
Another problem with connecting an earth to this type of fitting is they are very often multiple metal parts with unreliable physical connections between the parts. Earthing at one point is no guarantee the entire construction is effectively earthed.
That's exactly what its like. Lots of loose fitting rods and chains and the like.
Thinking it through and considering that;
1. The wiring looks to have been professionally done, and is correctly terminated and secure in plastic lampholders with no inner insulation showing.
2. Cable has only been lighting secured to the frame with ultra thin tie wire with no damage to the sheath/outer insulation.
3. Circuit is RCD protected.
4. There is no known local infestation of gymnastic flying squirrels able to reach high ceiling heights to chew cables (no external influences).
Then I'm inclined to install them as is....
get them fitted, then learn how to spell chandelier. :D:D:D:D.
Reply to Antique Chandalier - with no earth... in the UK Electrical Forum area at ElectriciansForums.net
Good point but then regular plastic switches aren't permanently running a wireless network module inside. It just seems odd not to have an earth...
