Antique Chandalier - with no earth... | on ElectriciansForums
Discuss Antique Chandalier - with no earth... in the UK Electrical Forum area at ElectriciansForums.net
Sheffield
[ElectriciansForums.net] Antique Chandalier - with no earth...
Hi all. So I have been asked to install a couple of 18th century antique chandeliers that have previously been ‘electrified’ (customers words!).
Anyway I am but uneasy about it in terms of earthing. There is the kind of 2 core cable you sometimes get with modern double insulated pendants lights, and the cable feeds plastic e27 lamp holders around the chandelier. The cable is tied to the metal frame with thin tie wire.
Physical check and all is fine. I would have preferred to get an earth down to the frame - but can’t.
Obviously no double insulation symbol.
Am I being over-cautious? Would you put it up as is?
I cannot see it properly , but if it is metal I would want it earthed.
I would not put it up as it is .
Maybe there is a way to get a similar 3 core in.
I would be careful with this as the alterations will be your responsibility.
Can you put up pictures of the fitting so we can see it more clearly? If it were me I'd be similarly cautious and would likely want to drill through it at some point to fit an earth, unless it really is crystal clear that all the metalwork is separated.
I took a few photos but they were all pretty poor. I was trying to keep the light in its transportation box....
Yeah, that's fair... I can also see why drilling through an antique light fitting might be considered a bit uncouth unless absolutely necessary!
Exactly.
There are some tiny bolted connections in the structure with what look like hand cut nuts ?!
Not for the faint hearted trying to get an earth to it - and it will always be visible if I went down that route. A nice bit of green and yellow on a chandelier?
put in a three core cable .Transparent Round Clear PVC 3core 6A Electric Flex Cable Chandelier CCF-534 0.75
Thanks Buzz. I’m wondering how to work that though - as the lamp holders are plastic with two terminals.
There are a couple of specialist companies that ‘electrify’ antique chandeliers. I am wondering what they use - but I suspect it’s 2 core double insulated for plastic lamp holders or 3 core for metal lamp holders...
Reply to Antique Chandalier - with no earth... in the UK Electrical Forum area at ElectriciansForums.net
Good point but then regular plastic switches aren't permanently running a wireless network module inside. It just seems odd not to have an earth...
