Any one else agree | Page 2 | on ElectriciansForums
Discuss Any one else agree in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Any one else agree these red crimps look cap
  • [ElectriciansForums.net] Any one else agree
What do guys normally use to extend cables when required??
Wouldn't it make for a better and tidier looking job to pull legs out of board and use a mf fitting and new legs into boards rather than crimps that look absolutely crap
if it's just a few need extendin, e.g. the cpc's are too short, i use ideal in line connectors in CU. if it;s a lot, then an adaptable din rail box, as in one i made earlier (see the blue peter connection). the cpc of the 6.0mm was re=routed after the photo.
I love doing these sort of domestics , they are right in my wheel house as a house badger.
Usually an IP box or Adaptable box like Tel is a very neat solution to multiple extensions to a new position.
If not I will fit the biggest board possible and use in line push connectors to lengthen cables and try to hid the joins behind the mcbs
Either way if I saw the consumers unit in the OP , I would be ripping the whole lot out and starting again...
Reply to Any one else agree in the UK Electrical Forum area at ElectriciansForums.net
thanks for the confirmation this is what i thought. i cant think of what use this device is . i have seen David Saverys Arc Fault Detection Device...
Which rcd is it? Is it one for everything, one for a few circuits?
