Are so you have also used chewing gum to hold a screw head on when it breaks off on the final turnnah. i can see the screw heads, but who's to say they've got screws attached.
Discuss Any other ideas? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That at best is a temporary repair until you can undertake the task in a professional manner.Using Flanders suggestion this is what I came up with in the end. I just drilled out each end with a hole saw and cut a slot with a hack saw so that the conduit finished flush with the adaptable box lid.
View attachment 32734View attachment 32735
Did you consider reinstating the earth continuity of the conduit or even testing it. Are there any IP rating issues? The customer will normally always go cheap but it's your name on the resulting repair.
Don't think this method would have been for me.
My preferred method would have been.
1 Pull out reinstate through box add a runner on the tube aid reassembly.
2 Install metallic box with suitable connectors.
Reply to Any other ideas? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
