Any recommendations for some cable shears? | Page 3 | on ElectriciansForums
Discuss Any recommendations for some cable shears? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I want to be able to cut through tails more easily. At present I am nibbling away at them with my side cutters which takes time and also doesn't leave a very clean cut.
I borrowed the builders cable shears and they literally just sliced though 16mm tails quickly and neatly. I have a set of bolt cutters but these are too big so I was looking for any recommendations on a set of cable shears?
Cheers all
[ElectriciansForums.net] Any recommendations for some cable shears?
If you get this type, you can reverse the handles to form a stripping knife. Quite handy at times.
The 'neilson' pair that tel recommended have arrived. Unfortunately they chop through 25mm with ease. I can only hope they wear out quickly so I can justify buying the lovely knipex ones :(
The sad thing is that I obviously wrote the above post in jest, however thinking about it I really do hope they wear out so I can get the knipex. Blimey, we love out tools!
You could speed this urge along by saving your new tool for use as an alternative to safe isolation.
cut a pair of live tails with the cheapos. then you can justify the knipex.
Reply to Any recommendations for some cable shears? in the UK Electrical Forum area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
