Any tips ?? Remembering formula
Paddy4444
Trainee
Hey I’m studying 2365 at college and I’m at the science part now .. any tips on remembering formula or is it just a case of going over and over it till it’s in your head .. any help much appreciated
I see what you’ve done, but I don’t understand what you’ve done!
What’s the need to substitute I for V
In what situation would you use V2?
The variations in formulae are to account for the known variables.
On a piece of equipment designed for 230V ac if you use an ohmmeter to measure the resistance of the load then you now know two variables, R and V, if you want to know the power then you can use P=V²/R.
It would also be possible to get I from I = V/R and then use this calculated value for I in the P = VI equation but then you have to do two calculations.
Effectively you do the first calculation, I=V/R, in advance by substituting V/R for I in the P=VI equation.
Other versions of the equations can be used where you know different values.
I am teaching electrical science at the minute with my students and have just covered ohms law, series, parallel, series+parallel and power.
I have found that it is easy for them to remember ohms law (V = I x R) and power formula (P = V x I). I then say that they can either remember the other 2 power formulas (P = I^2 x R & P = V^2/R) or if they can transpose and substitute formula then they only need the 1st two formula to work out the rest.
this might be useful.:
Flash cards. That's what I used. Have a Google, there's software that lets you make your own. It helps having a buddy so you can each test each other. I found it worked very quickly. I can't remember any of them now - well, apart from Ohms Law, and power.
Paddy4444,
telectrix,
