Anyone good on appliances? | on ElectriciansForums
Discuss Anyone good on appliances? in the Electrical Appliances Forum area at ElectriciansForums.net
England
Seem to be having an intermittent fault on my AEG condenser tumble dryer. It occasionally throws up an EH0 code - which states it could be a power supply fault. I use an extension lead (white flex type), which I changed, but it’s still occurring. I’ve been used a plug checker, which states everything is ok. I have to keep sponging the bottom bit out (where the water filter is).
Anyone any ideas?
Many thanks.
they fill up with lint which can cause the moisture try clean out as much as you can if its a condensor dryer you will have to do a full strip down
Also check door "filter" for any damage / split = not too obvoius... more lint where it doesn't belong ..
(I'll be going back to blowing warm air outside ..)
Reply to Anyone good on appliances? in the Electrical Appliances Forum area at ElectriciansForums.net
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of...
