Anyone Know What This Is? | on ElectriciansForums
Discuss Anyone Know What This Is? in the Australia area at ElectriciansForums.net
hpmuk
Hi All,
I was stripping wallpaper today in my hallway.. When i came across this.. Some kind of Square box?
[ElectriciansForums.net] Anyone Know What This Is?
When i touched it it gave me a shock.. If i turn the breakers off for the doorstairs lights then its no longer live? ANyone know what it can be?? Or anymore info?
Thanks In advance
Luke
redundat cable not used and "stuffed" as usual in wall! chip plaster away and get it terminated properly!
if in any doubt give a local spark a ring! quick fix job rather been safe than sorry for future times! no more than £35 to fix!
When i put my voltage tester on about on the wall below it.. about 30cm x 60cm is live?
Cheers
M8 its not your led's lighting up, its safety signs ........sorry.... unless you guys have different fluke to me my top right symbol dont tell me if the water is hot? QUOTE=hpmuk;237482]They were the led's lighting up.. nobody would understand if i explained them
Thanks[/QUOTE]
Reply to Anyone Know What This Is? in the Australia area at ElectriciansForums.net
i think dan was referring to the OP where they mentioned it was found when removing mirrored wardrobes.... maybe nothing to do with the mirror...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
