Anyone spot the mistake in this install? | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Anyone spot the mistake in this install? in the UK Electrical Forum area at ElectriciansForums.net
Earthing conductor looks correct size, appears to be the correct amount of cpcs required for amount of circuits, bonding will be going off to another met closer to service head....... you got me Pete! Curious now.......
Not another MET, there is only one MET for an installation (assuming there is only one incoming supply)
If there is another terminal after the MET where binding conductors are connected it is an EMT or EMB (earth marshalling terminal or bar)
Never heard of it. I was always taught that the earth bar inside a consumer unit for all intents and purposes was considered a main earthing terminal, especiallly when met is referenced to in bs7671. Another example is when referenced to in your schedule of inspections on either an eicr or initial verification
Reply to Anyone spot the mistake in this install? in the UK Electrical Forum area at ElectriciansForums.net
Have had the issue of led lamps still glowing gently when switched off, snubber worked a treat on more than one occasion 👍🏻
What was the assossors name? Was it warren by any chance? Did you get it sorted in the end?
Recommended Sponsor News
Hi everyone,
Pete999
Northampton
United Kingdom
Retired Electrician
Business Name
None
Pete's Videos
