Anything you can do I can do better! | on ElectriciansForums
Discuss Anything you can do I can do better! in the UK Electrical Forum area at ElectriciansForums.net
UK
No you can't. yes I can!
Another (late) friday game.
Thought it'd be fun to have a p**sing contest:D
Someone says work they've done before reply if you've done it bigger and better.
I can see this being fun as there's someone(tel) that'll go over the top :D
Biggest cable I've worked on is 35mm 3 core armoured
Go!
Wendy house stuff. try 240mm 4 core into a gland box with 2 labourers holding cable up , while you're glanding it with 3ft. stilsons..
[ElectriciansForums.net] Anything you can do I can do better!
I've had worse!
400mm 4 core swa is the largest I've worked with. To be fair, my company hired a cable gang to pull that one in, I helped, but the most I could do was lift it and go with the flow. Back breaking. The standard cable on the same site was 240mm 4 core, 100's of metres of that went in. Now self employed I've been demoted to domestic installer :)
Im in the same boat steve . I find it difficult to get anything other than domestic and light commercial being a non vat one man band :(
Reply to Anything you can do I can do better! in the UK Electrical Forum area at ElectriciansForums.net
The video's are an accompaniment to the Book and referenced throughout.
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
