N
nbe
I have an apartment with this strange EDF tariff called Economy 9. It is basically 9 hours of off-peak electric that are spread throughout the day, unlike Economy 7 which has them all at night.
There is a single Horstmann radio telemeter and a single CU. However the CU is wired up with two main switches and there are two live feeds coming out of the meter (presumably, the "heating" and "everything else" feeds) and these are wired into the corresponding main switches on the CU.
The left hand side main switch on the CU has all the fuses for heating, immersion etc. And the right hand side main switch has the fuses for everything else like the ring mains, cooker, lighting etc.
This doesn't seem right to me as it means that whenever the off peak comes around then only the heating of the apartment will benefit. Whereas everything will still be charged at the normal rate (which on Economy 9 is about 16p!).
First of all I need to know whether this is normal or not. And secondly, if it is not normal and it is legal for me to do so, what can I do to correct the situation?
Thank you very much!
