application for pme | on ElectriciansForums
Discuss application for pme in the UK Electrical Forum area at ElectriciansForums.net
North Devon
Hi
one of my customers have contacted western power distribution about getting pme installed as there is no reading when an earth stake is installed
they have done a site visit and have asked their electrican (me) to do send of a request form
i have trawlled the website and cannot find the right form, can anyone help me?
Hi
What do you mean ''there is NO reading when an earth stake is installed?? Your ''Always'' going to obtain a reading/value, no matter how bad/high it may be!!
What's the maximum Ze value your MFT, or separate ELI tester measures then?? The only other thing i can say, is that there must be a break in the earth rod conductor, if your not getting any reading at all!! So what are you going to do, if the supply to your customers house, doesn't have a PME connection available??
I had one a few weeks ago. 1960's build. Unsheathed earth to gas and water no main earth. Earth readings were good though. I got wpd to install a pme.
Should be a problem if you ring them. The local team came out to pme it. Then I went back connected up new earth and commissioned new work.
Checking earth and bonding should come before any work is carried out.
Also, have you left it like that? An earth connection tends to be quite important you know.
- - - Updated - - -
Oops Geordie beat me to it:)
Hi
ring the DNO....they will send out a form for the client to complete....and send back to them...oh, and when you ring the DNO do ask to be put straight on to the duty engineer wont you....otherwise you will be there for ages trying to get through to some mad cow on the other end of the phone...
- - - Updated - - -
I do hope you haven't left it like that while you wait for the bits of paper to arrive, be filled-in, returned, actioned or not ..... etc etc.
As soon as I started reading this I though we’re going to get to the “I’m going back next week” syndrome.
It’ll be OK for now??????
ring the DNO....they will send out a form for the client to complete....and send back to them...oh, and when you ring the DNO do ask to be put straight on to the duty engineer wont you....otherwise you will be there for ages trying to get through to some mad cow on the other end of the phone...[/QUOTE]
I thought it was an obligation to shoot and burn all mad cows?
Sorry I’m not in the farming section!
I`v witnessed this one in person.....a temporary rod was put in....i asked if the `installer` was going to provide a temporary upfront RCD to go with his rod...
`eh?` was the reply..
Reply to application for pme in the UK Electrical Forum area at ElectriciansForums.net
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
Reminds me of one where I got the DNO in to swap a L - N fused metalclad head in a church got talking to the 2 guys doing it the guy doing most of...
