Are mains sockets permitted in bathrooms? | Page 2 | on ElectriciansForums
Discuss Are mains sockets permitted in bathrooms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The day anyone on here notifies building control they are doing work in their bathroom I'll eat my hat lol.
just for a laff. i'll install a new bog and notify it, just to see you eating your hat. :D:D:D.
Well you will be the first one that has ever done it lol
Pity!
As I said above. You cannot leave live cables in the wall and just plaster over them, unless they are at least 50mm from the surface.
So you have two obvious options
1. Rewire the socket so there are no cables in the wall. This may be tough as the cables come from two directions, but there may be a service duct in a corner, or other routes that the cables could take. You'll obviously need to find a location for a junction, or two.
2. Connect the conductors together, in the existing back box, using some insulated terminal block, or Wago-type connector.
Then put a blank plate over the back box, but on top of your new plasterboard so it can be seen.
Sounds like it's an upstairs RFC feeding sockets below and a single T&E drop.
Not a 70's built house by any chance?
Pity!
Yes, that's the route I'll take terminal block with a wall plate.
Erm...what sauce would you like on your hat, MDJ?
I installed a new loo and got a Building Warrant and Completion Certificate for that.
The lady from BC who inspected it was in the house less than 1 minute, said "Nice shower!" and left!
Well there is always one t!t
'Thank you for your quick reply. The socket is too close to zone 1. Behind the socket three cables converge, bearing in mind that I am replacing the plasterboard in that area what is the best method of connect the cables together?'
Either use the existing back box, suitable connectors and a front plate or a suitable maintenance free junction box. Any further information, would be a step by step guide, which is against forum rules.
I'd consider employing a competent electrician. Such work could be notifiable to local building control.
You can build a cupboard around the socket
Reply to Are mains sockets permitted in bathrooms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello everyone, I would like to put a washing machine in a cabinet in the bathroom, and run it's power cord through the wall that separates the...
Tiling hallway through to bathroom but needs to be done in two parts Hi, I am planning on getting my hallway tiled and continuing the tiles into...
Dh1500
