The day anyone on here notifies building control they are doing work in their bathroom I'll eat my hat lol.
Discuss Are mains sockets permitted in bathrooms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
just for a laff. i'll install a new bog and notify it, just to see you eating your hat. .The day anyone on here notifies building control they are doing work in their bathroom I'll eat my hat lol.
Well you will be the first one that has ever done it lol
BothThen he needs to remove the cables from the wall completely as there will not be anything denoting the presence of cables in the wall.
@diyterry Do the cables come up from the floor or down from the ceiling?
Pity!Both
Spot on 1860's house......rewired in the 70'sSounds like it's an upstairs RFC feeding sockets below and a single T&E drop.
Not a 70's built house by any chance?
Yes, that's the route I'll take terminal block with a wall plate.Pity!
As I said above. You cannot leave live cables in the wall and just plaster over them, unless they are at least 50mm from the surface.
So you have two obvious options
1. Rewire the socket so there are no cables in the wall. This may be tough as the cables come from two directions, but there may be a service duct in a corner, or other routes that the cables could take. You'll obviously need to find a location for a junction, or two.
2. Connect the conductors together, in the existing back box, using some insulated terminal block, or Wago-type connector.
Then put a blank plate over the back box, but on top of your new plasterboard so it can be seen.
Use Wago or similar, not those horrible choc block things...Yes, that's the route I'll take terminal block with a wall plate.
Well there is always one t!tErm...what sauce would you like on your hat, MDJ?
I installed a new loo and got a Building Warrant and Completion Certificate for that.
The lady from BC who inspected it was in the house less than 1 minute, said "Nice shower!" and left!
If you can remain sober then you have a chanceAye, I feel a right t!t now...
Maybe I'll get to feel the left one later on! Yay!
You can build a cupboard around the socket'Thank you for your quick reply. The socket is too close to zone 1. Behind the socket three cables converge, bearing in mind that I am replacing the plasterboard in that area what is the best method of connect the cables together?'
Either use the existing back box, suitable connectors and a front plate or a suitable maintenance free junction box. Any further information, would be a step by step guide, which is against forum rules.
I'd consider employing a competent electrician. Such work could be notifiable to local building control.
Reply to Are mains sockets permitted in bathrooms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
