Are these wires neutral? | on ElectriciansForums
Discuss Are these wires neutral? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Rayleigh
I'm currently in the process of running neutral wires around my house to all the light switches so that i can install some of these new wifi smart switches to control all of my lighting.
One of my light switches has a black and a blue wire connected together separately from the switch shown in the attached photo.
How can i tell for sure if they are neutrals?
[ElectriciansForums.net] Are these wires neutral?
Dug out an old multimeter with longer wires to test the continuity between the switch and the light. Turns out they are neutral.
Win for me as i don't have to run a neutral to this switch now!
I'm curious on how you are going to run Neutrals everywhere.
(without ripping your house apart! :))
All the switches are on stud walls. Downstairs are close to the landing which I'm waiting to carpet and then upstairs I'm going to try running them down from the loft. Will be interesting to see if it is possible or not.
Reply to Are these wires neutral? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You were correct those are neutral wires, it worked! Many thanks
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
