armoured cpc problem | Page 2 | on ElectriciansForums
Discuss armoured cpc problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I would bond the pool house to the earth spike and similarily connect the gas main and the armour cable to the same spike (via a met or the earth bar in the consumer unit).
I agree that there will be multiple parallel paths due to the armour and the copper gas pipe. The break in the armour in the joint works in your favour here.
Ideally the gas pipe would have a plastic joint inserted to isolate it from the main house.
Then treat the pool house as a TT installation.
Reply to armoured cpc problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
What readings were you expecting for the cable prior to testing? What is the make of the protective device? Is there any previous paperwork [test...
totally agree
