As there has not been any activity in here lately...
Trying to get a value for the capacitor needed, the 21.645 is divided by 10 to the 6 as the capacitor that will be needed will be in microfarads!
i am confusing myself to be honest
So, we worked out that the amount of reactive current that the capacitor needs to rectify is 26.22A right? You need to work out the ohmic reactive value of a capacitor that would allow 26.22A to flow through it. A tip.... Ohms law :)
The result of this calculation should give you an Xc value, one that you can then convert into Farads using other information available.
Thanks for the help with that , much appreciated. :smile:
Could you possibly post 1 with different values but the same scenario, i can work through it to make sure i can get the right answer without any help this time.
MS Paint :D
Here we go:
I have 0.80 for the power factor so I suppose that's close enough.
The capacitor value needed to correct to 0.95 is not 51μF though.
