Discuss AT28C16 EEPROM learning experiments in the UK Electrical Forum area at ElectriciansForums.net
I used 4 jk flip flops each connected as a type T (toggle). I made some combinational logic but could have used a look up table to cause each flip flop to change state or not depending on the current state - ‘ if then otherwise‘ type logic. This makes what is called a 'finite state machine'.Also mister @marconi , did you made that gray code circuit already? Do you have a movie to present it? Also Im curious on your approach/ design. How did you use it or at least assemble it?
Reply to AT28C16 EEPROM learning experiments in the UK Electrical Forum area at ElectriciansForums.net
