the power fail alarm is a good option. no wiring, no regs. to worry about. it's just a plug, program and play device.
Discuss Auto resetting RCD? help please... in the Electrical Tools and Products area at ElectriciansForums.net
Having said all that just looked up some aquarium kit and it does all say it should be used with an RCD and if that's what the manual says ...
Rather than trying to remedy the symtom, address the cause of the fault that is tripping the RCD. RCD's should be quite reliable and a 200W heater should not be a problem for it.
If the problem is caused by spikes from timeswitch then change it for a soft start triac one.
Another alternative solution could be to fit a safety isolating transformer between the tank wiring and the wall socket. This would remove any earth connection that may cause the RCD to trip.
Reply to Auto resetting RCD? help please... in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
