C
Crosswire
Anyone know of a reg that says 3036 fuse boards automatically have to be upgraded?
I think 'no', but other sparks have said otherwise........
Thoughts pls....
When customers ask me if their old 3036 cu needs changing after an EICR and everything is ok I explain it like this:-
It's like having a classic car with no ABS, seat belts, side impact bars. Ford for example would not be able to manufacture that car now without the new up dated safety laws but there is nothing stopping you from driving it today if it passes a mot (eicr).
You can have a modern cu with all the new up dated rcds and mcbs but that's your choice. Don't let anybody tell you that it needs changing just because its old.
If the board is protecting sockets that can be used outdoors, then there is an argument that they require RCD protection. (best practice guide backs this up also) usually the easiest way is to swap the board.
Yes, another possible reason for advising a board change there. BS3036 fuses are still a recognised means of protection of course, but each job assesd on it's merits. Then options presented to client. There's nothing wrong with that, surely?
Yep I agree, to say just "It needs changing because it's old" is wrong.
Socket-outlets used to supply mobile equipment outdoors can be protected by simply using an RCD socket.
Many of these are actually 10mA, which may be considered safer than using a 30mA RCD at the board.
The general thought is that any socket downstairs could be used outdoors, putting RCD sockets all over the ground floor isn;t really an option.
I ask which socket is normally used for outdoors equipment. Majority of the time its the one in the kitchen next to the door, just change that one and inform home owner to use that one only for o/s use.
Thats not gonna happen is it?
Ok fair enough it really depends on the house layout.
Alternatively you could spur off the ring and install an IP55 rcd socket outside. Easier to use, designed for that sole purpose and cheaper than a cu change. Although it still won't stop them from plugging in an extention lead into the none rcd ring?
There has never been a requirement for "any socket downstairs could be used outdoors" to be RCD protected.
The wording in the 17th has been changed specifically to deal with this misconception.
It used to be in the 16th, that any socket-outlet that may reasonably be expected to supply portable equipment outdoors shall be provided with 30mA RCD protection.
It was found that this requirement was being used for socket-outlets that would not reasonably be expected to supply portable equipment outdoors, and in some cases this requirement was being used for equipment that was not even portable.
The requirement in the 17th, is that mobile equipment used outdoors shall be provided with 30mA RCD protection.
As such any socket-outlet that is not being used to supply mobile equipment outdoors, does not require 30mA RCD protection.
In most domestic installations, the distinction is moot, as all socket-outlets intended for general use by ordinary persons, now require 30mA RCD protection.
The distinction is really only relevent where a PIR/EICR is being conducted.
As such it would affect which code you applied.
A lack of 30mA RCD protection to socket-outlets would warrent a code 4/C3, whereas a lack of 30mA RCD protection for socket-outlets used to supply mobile equipment outdoors would warrent a code 2/C2.
Some of the Wylex boards have the carcase made from wood.
The NICEIC view this as being unsafe, as wood is combustible.
I guess they don't know that you can set light to plastic.
That has to be one of the biggest Myths out there, ...the Wylex ''Wooden Carcase'' CUs need changing because they can catch fire!! These were the ones with the bakelite type fronts and covers, before they changed to plastic...
In all my years in the Electrical industry, i've never seen or known, of or even heard of one of these old wylex 3036 CU's wood carcase ever catching fire. They just DON'T!! ...The wood is a highly seasoned and treated hard wood, you can't even purposely set fire to them easily. Bung on a fire, and they will be the last bits of any wood to burn!!
Now on the other hand, how many Plastic CUs have we seen reduced to molten blobs on the floor?? lol!!!
I know there isn't a specific requirement, but surely it is reasonable to assume that downstairs sockets could be used to supply mobile equipment outdoors. Hence the reason why time after time you see older installations with the downstairs ring circuit RCD protected.
back in 1981, the requirement was that one socket be RCD protected for the use of portable outdoor equipment, however, this was found to be inadequate. These days, on the older installations, how do you determine which sockets are being used for such a purpose? simply put, you can not.
RCD's aside, another reason we should be advising that these old dinosaur boards should be pulled out is this..
I've lost count how many times I've come across a wylex board to find 30amp fuse wire used in a 5amp lighting circuit.
Automatic Board Change?
Australia
Crosswire,
Knobhead,
