Hi , i went out to a automatic cow brush that had melted its 1ph motor the other day and after stripping the unit off the wall , due to the size of it we decided that the client would take it in to a re winders local to him as i by the time i had gone back to the yard to fetch one of our plant trailers and took it and fetched it back from our usual ones it would have been around a 140 or so mile round trip .
The trouble is that the ones he used , did the usual favourite trick that most re winders seem to like doing of removing any trace of how to re connect it !
Normally i either know how anyway or we mark and photograph the old one prior to removing , but as it was sent as a whole unit ( brush and frame ) i had expected that they would have had the courtesy to have just reconnected the wires into the new motor they have fitted and not just chop the cable instead !
The unit has a small pcb that has a 1ph feed in , a feed out and return for a micro switch that sensors when the cow wants to use it and then the feed out via 4 conductors to the single phase motor ?
This one has me stumped and as we do not deal with the re winders he used , we are getting the old " Your electrician should know this ! " , any ideas appreciated !
It is a 1ph electric cow brush made by Agricow
Hopefully the pictures tell more of the story !?
