AVI (Approved Voltage Indicator) - Common Misconceptions | Page 2 | on ElectriciansForums
Discuss AVI (Approved Voltage Indicator) - Common Misconceptions in the Electrical Tools and Products area at ElectriciansForums.net
And even when you know it is off , work as if it isn't.
Sir, I think this would be worth elaborating for EF readers giving examples of what you do. The electricians doing our current extension wore dextrous rubber gloves for example - the plumbers wore similar gloves more I think for the grip and prevention of cuts.
It might be these:
Ansell ActivArmr ActivArmr Electricians Gloves Grey Large - https://www.screwfix.com/p/ansell-activarmr-activarmr-electricians-gloves-grey-large/99723
The organisation I worked for taught the 'one hand rule' for example to avoid across the chest/heart shock currents.
The obvious one is to always use insulated snips for cutting cable, even if you know it's dead. One day it won't be.
Same for insulated screwdrivers. If you get into the habit, then it won't go so badly for you when, eventually, you tighten a terminal that should be dead, but isn't.
i always check tightness of terminations when live. if it sparks, it's not right. therefore the vde drivers are a must, otherwise i might get a tingle that wakes me up.
For I2C : My Dilog AVI has an 18K input impedance. High enough normally of course (if no other leakages), but too low for it to be driven anywhere close to 230V by a Martindale proving unit (which can only drive about 3mA, - hence about 60V on testing the AVI).
i reallyneed to check the input impudence of my AVO 8.i forgot what it was back in 1982.
I find it hard to believe,that several electricians suggest the test described,by the OP...one numb one...but plural?
The fundamental requirements,are to both understand how the test equipment functions,and how to use it,to discover whether safe or not.
Experience of the various scenarios,where line voltage can occur,would make ALL the necessary combinations of testing,second nature.
Line/neutral reversed,a live neutral,live earth,or all live...are all possible or probable occurrences,and all testing should indicate such.
The gentlemen advising otherwise,have possibly never inspected a connected burger bar,by first putting one probe on the yard surface,and the other on it's brightwork :)
If you're testing for isolation it should be isolated. If so, why worry about an rcd tripping.
It should all be dead, so test it all.
Fault finding may be different.....but it should have tripped, anyway.
Just an appendage,to my previous post,which mentioned correct understanding of a test instrument,would be to remember that an AVI is not only used to check for safe isolation.
It is as handy,though not it's primary use regarding this conversation,for proving a voltage present.
A quality AVI,with maybe resistance and DC capability,can be a fine,compact troubleshooting device.
I have an old TPT220,which stays in the glove box,or hand luggage...and it's paid for itself a hundred times over:)
Reply to AVI (Approved Voltage Indicator) - Common Misconceptions in the Electrical Tools and Products area at ElectriciansForums.net
I created a voltage drop spreadsheet for this sort of thing. I used to use it to calculate the drop when designing regular 230V lighting circuits...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
