Back entry wiska box | on ElectriciansForums
Discuss Back entry wiska box in the UK Electrical Forum area at ElectriciansForums.net
impish15
Trainee
Supporter
Bromley
Hi all,
I’ll be fitting a new outdoor light next week. Does anyone have a link to a back entry wiska box they use/recommend please? This is what is currently installed
Many thanks in advance
  • [ElectriciansForums.net] Back entry wiska box
I usually just open the drain hole at the bottom of a 308 and then cut a 20mm hole in the back of the box... apply a liberal amount of sealant on the back face and then screw it to the wall. If you're really concerned, run a bead of sealer half way up each side and across the top.
I've been doing it this way for many years and have thus far not had any issues with this approach.
Many thanks. Clear and concise. I’ll go with this
Reply to Back entry wiska box in the UK Electrical Forum area at ElectriciansForums.net
If it's underground I've always favoured SWA with good old fashioned resin joints. I would make a 3 way resin joint below ground, no enclosure...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
