- Joined
- May 7, 2009
- Messages
- 129
- Reaction score
- 1
hi guys
am i right in saying that generally the higher the amps the lower the volts ??
watts divided by amps = volts
watts divided by volts = amps
amps x volts = watts
taking that in mind a 12v extra low voltage spot light which is 50 watts = 4.1 amps
240v low voltage 100w bulb = 0.4 amps
if this is true wouldn't that make 110v more dangerous then 240v because of the high number of amps?? or is 110v not enough voltage to push the current through the resistance of a person. getting a bit confused any advice would be great. cheers in advance
