good now i can explain to my boss that higher voltage doesn't equal higher current :)
But is does.
Assume resistance remains unchanged e.g. 10 ohms
230 volts divided by 10 ohms = 23 amps
2300 volts divided by 10 ohms = 230 amps
so the current in a conductor is directly proportional to voltage, and inversly proportional to resistance.
Can't remember who said that........;)
Lightning?
According to BS7671 that is an "Overvoltage of Atmospheric Origin".
Are we getting into semantics? Are you saying that lightning is not an example of a discharge?
There is of course there is a voltage associated with it. :confused:
BS7671 might be the bible of electricians, but i don't think it is held in such high reverie by physicists.:p
No. Was just saying that the IEE have a much fancier term for lightning!
Yes they do :D
-"did you see that thunder and over voltage of atmospheric origin storm last night , it rained feline and canine small mammals afterwards" ;)
Voltage is the water pressure...Amps are the water bubbles...More pressure..more bubbles
Not quite. Using the water analogy, which is one I use to explain electrical terminology to those with no electrical background, voltage would indeed be the pressure pushing water through a pipe, but the diameter of the pipes, or a turbine introduced into the system would equate to resistance, which would affect the rate of flow of water, the rate of flow being the current (Amps).
So now they have lowered the domestic voltage down to 230 in some areas, this equates to more amps used, so my meter turns quicker and my electric bill gets bigger!
No you use less amps.
I=V/R
Resistance will remain constant so for an appliance with a resistance of 18 ohms
240/18 = 13.33A
230/18 = 12.77A
back to basics higher the volts lower the amps?
chrisreid186,
Scud,
TrueNAS JBOD Storage Server
