back to basics higher the volts lower the amps?
No you use less amps.
I=V/R
Resistance will remain constant so for an appliance with a resistance of 18 ohms
240/18 = 13.33A
230/18 = 12.77A
That's correct,
Now if from that you work out the power you get 3.199 Kw at 240v @ 2.937 Kw @ 230v.
Granted...With respect....Long time since ive had to Really think....Thats why im on here...
Why is lightening always quoted in the amount of Volts...and not the...??? current finally discharged
So now they have lowered the domestic voltage down to 230 in some areas, this equates to more amps used, so my meter turns quicker and my electric bill gets bigger!
No it doesn't. Your electric meter doesn't measure amps, it measures kilowatt hours. If you use a one kilowatt heater for one hour, you use one kilowatt hour. Current and voltage are irrelevant to that. Additionally, while the standard is 230V +10%, -6%, (since 1995), you will find that your voltage still sits around 240V.
Somebody needs to rewrite the equation P = I x V then . Power (the rate of energy dissipation) is a combination of current and voltage. Energy use, as you correctly say is, a combination of power and time.
How do you work that out? Current and Voltage are used to calculate Watts
Power (Watts) = Current x Voltage
*EDIT* pushrod pipped me at the post :D
Why do so many sparks seem to struggle to grasp even the most basic of concepts....
Worrying TBF
I think I put my point across badly.Perhaps I need to rephrase. Even if the faulty supposition that a decrease in voltage would lead to an increase in current, the number of units used would be the same or arguably less. The kilowatt hour meter registers the product of voltage, current and time. Does that make my point clearer?
chrisreid186,
Scud,
