Backbox Disaster | on ElectriciansForums
Discuss Backbox Disaster in the UK Electrical Forum area at ElectriciansForums.net
soulman
Durham
Hi, I returned to a property today for second fix, all was going well until i hit the sockets! The metal backboxes i installed, the fixed lug on one side would not hold the screw. The screw would just turn & not nip up. There was 6 in total out of 30 that were faulted. (Appleby)
Anybody got any ideas on how i could rectify this without removing the boxes.
Cheers
You could remove the lug or bend it back ,drill a 3.5mm hole in the back of the box and tap it with 3.5mm tap , then put in an extension screw , then use a normal 3.5mm screw , but watch the length of the screw though, thats what I have done in the past,,
Reply to Backbox Disaster in the UK Electrical Forum area at ElectriciansForums.net
The lug to use for this purpose is the Square D / Schneider Electric QO/Homeline 100 Amp Auxillary Neutral Lug Kit for Electrical Panel/Load...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
