Backbox Disaster | Page 3 | on ElectriciansForums
Discuss Backbox Disaster in the UK Electrical Forum area at ElectriciansForums.net
soulman
Durham
Hi, I returned to a property today for second fix, all was going well until i hit the sockets! The metal backboxes i installed, the fixed lug on one side would not hold the screw. The screw would just turn & not nip up. There was 6 in total out of 30 that were faulted. (Appleby)
Anybody got any ideas on how i could rectify this without removing the boxes.
Cheers
Never a disaster there is always a way round it the guys on this site are so talented in little problems like tis thats why we are all here the way I would do it as has probably been mentioned is b removing a unfixed lug and using it as basically a nut bit fiddly to get it on but it works a treat bugger for any one removing it in the future mind lo
Get some socket screw extension studs (google them, should be a link to amazon) and use a removable lug from another backbox and screw the stud in, using the good lug as a washer behind the knackered one. Then tada! Works a treat for me everytime, no drilling or anything!
Hi Mark80,
love this idea, just wondered though, can you still get a screw in the extension stud, as their won't be much room left from accessory to stud for a screw....
Yeah, you're basically hoping the backbox is not perfectly flush with the wall or you might struggle a bit. Sometimes I just have to cut the screw down to get it all the way in, but never had a problem yet TBH.
I always do as Mark says and use hexagon brass screw extenders , but put 2 x 3.5mm brass nut's pinched up on the back as well , ( get them from the wholesalers at the same time ) that way the extender will not work loose and just spin round if the accessories is unscrewed again .
You do have to be careful though as to the length of finishing screw to use as it has less space to go before bottoming out , and if not cut cleanly the threads will pick up on the brass extension and you are back to square one !
Reply to Backbox Disaster in the UK Electrical Forum area at ElectriciansForums.net
Norcal - thanks, belatedly. 'Tis the season when I don't get anything done, even though this project is near the top of the list. Per your...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
