Bad practice FCU to lighting circuit | on ElectriciansForums
Discuss Bad practice FCU to lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
London
What are your guys thoughts on this a 13amp FCU feeding of a ring feeding a light. I know usually people fuse at 3amp but if unlikely to cause overload does it actually have to be fused down?
TBH not the end of the world if a 13Afuse used I suspect it will break within time parameters. Also if it’s off a socket then probably RCD protected.
Obviously it should be 3A, but if someone has popped a 13 in by mistake not the worst thing I’ve seen. definately change it for a 3A now you have seen it.
never deliberately fit a 13A when it should be 3A. That’s just silly.
Reply to Bad practice FCU to lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
Thanks for the advice.
