Basic stuff for basic blondes | Page 23 | on ElectriciansForums
Discuss Basic stuff for basic blondes in the UK Electrical Forum area at ElectriciansForums.net
Sarz11
Hey just wondering if anyone has got any nice simple examples in the form of questions that you can offer in regards to working out earth continuity. These formulaes are driving me insane and i need more things to look at. Il ask my tutor too but u lot know a bit so thought id see hehe. Im thinking bout dying my hair see if this helps that or the electric cable rnd the neck. Hehe no really just some things i can look at and try work out in my pretty little head coz its alright learning but iv got no one to show me at min and i need to be pro active. Ok rant over. BE NICE AND SIMPLE BASIC VIRGIN ALERT thanks. Obv im working too so il be checking and looking when can if ppl reply
thanks
Sar x
I never said that Zs is the sum quoted, what I said was that using that sum is a perfectly acceptable method of obtaining a value.
Another thing that's often mentioned is that Ze can be obtained from the DNO by enquiry. They'll just give you the maximum figures as quoted which will probably bear very little resemblance to the value you'd get if you measured it but it's still an acceptable method.
As was said by someone else (Dillb I think) I've also seen exam questions worded like that and the correct answer is to use that sum.
yes...and another one i`v seen creeping into threads of late is measured & nominal values of Ze...and where they go on forms...
yes it is, some of the answers to your exam questions will be in there, regardless of what is actually said on here the correct was to calculate Zs=Ze+(R1+R2) and you be expected to know that in the exam.
and where to apply the 0.8 correction factor....that is to say to measuered or tabulated values of Zs...and when..and when not to apply the 0.8 correction factor Ze+(R1 R2) V direct Zs
It's acceptable because it's weighted on the side of caution - both max Ze by enquiry and Ze + R1 + R2 ignoring bonding, both these methods employ a safety margin to simplify testing...
Ok for the 5wws but if you have a borderline value, you will need to test 'properly'
a direct measurement of Zs is always more desirable as its a true value of loop...not gained by applying a `hot & `cold` measurement....
plus it takes into account reactance...hence `impedence`
Just because we never use it doesn't mean we should neglect to mention it as sarz will probably be asked to use it in her exams.
This formulae is more often used as
R1+R2=zs-ze
Because we are not always allowed to power something down and you are allowed to calc some values for test sheets, not ideal but its better than nothing
Reply to Basic stuff for basic blondes in the UK Electrical Forum area at ElectriciansForums.net
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
In the mind of someone lying there wide awake at 3AM, just about anything.
Recommended Sponsor News
Hi everyone,
