Bathroom Extractor Fan (Zone 1) Help Please! | on ElectriciansForums
Discuss Bathroom Extractor Fan (Zone 1) Help Please! in the UK Electrical Forum area at ElectriciansForums.net
London
Hi all,
I need to change my extractor fan which is in Zone 1, I have found a extractor fan as below for Zone 1 that does not need a separate transformer, as long as a RCD is present. Will the current RCD's be sufficient? I know the RCD is working, as I connected the wires wrongly when testing the old fan and it flipped.
Any advice will be much appreciated, thank you!
Monsoon IP45 Silence Axial Extractor Fan 100mm with Timer £39.92
https://www.electricalcounter.co.uk...ial+Extractor+Fan+100mm+with+Timer/2612098060
My consumer unit:
[ElectriciansForums.net] Bathroom Extractor Fan (Zone 1) Help Please!
Old existing fan:
fan in zone 1 should be IP44 or better. your IP45 will be suitable, subject to RCD protection and any other regs; that IET have dreamt up.also anything has got to be an improvement over that old fan
1. IP24 ?????
2. bare cpc
3. where's that other cpc going off the screw?
3. somebody not heard of sleeving 3 core/E conductors
4. what's with the spare black just sitting there?
It would be better to get a sparky to check it over.
Once it is installed the proper tests will be carried out after with a tester.
Just caused the RCD 'flipped' doesn't mean it is working btw.
looks like you only have perm live and neutral connected at the mo so you need to check if the black core is connected at the other end to trigger the new fan on as the old one has a humidistat and it looks like it wasn't connected
Reply to Bathroom Extractor Fan (Zone 1) Help Please! in the UK Electrical Forum area at ElectriciansForums.net
Hey all, This weekend we are discounting a range of bathroom & extractor fans. All of these products are currently in stock for fast delivery...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
