View the thread, titled "Bathroom fan with timer" which is posted in UK Electrical Forum on Electricians Forums.
5tan the man
Whats the sequence of fitting a extractor fan with timer with regards to iso switch/fused spur/fan ?
I have gone for 3core n cpc from the ceiling rose to a 3pole iso switch, then 3core n cpc to supply side of fused spur, joining the permanent live and switched live ,then out from the load side to the fan with 3core n cpc splitting the two lives to corresponding terminals. Is this right ?
This is an old debate, some of us fit fan isolators and some of us don't. Personally, I always fit an isolator for maintenance and convenience. However, there is no "requirement" that you fit one, just a recommendation, as the MCB can be used for isolation if needed. Building regs say that it is a good idea to fit one in a room with no window, but again, it's not a requirement (although many architects will specify it on new builds/extensions).
IEE guide for electricians states: isolation required where bathroom as no window and supplied from lighting circuit. Which Building reg states otherwise?
Reply to the thread, titled "Bathroom fan with timer" which is posted in UK Electrical Forum on Electricians Forums.
