Bathroom lights RCD etc | on ElectriciansForums
Discuss Bathroom lights RCD etc in the Australia area at ElectriciansForums.net
T
timo
Called to quote for installing some IP rated down lights in a bathroom. Told guy he needed an RCD for altering light etc and he wasnt pleased. Some old un-named mcb's in his C.U so i told him either a seperate 1 way c.u would do it or a new C.U all together to bring it upto date. Nope didnt want it :( Why do people think its just put that there and off you go..... Grrrr
Anyways i was thinking, could a RCD Spur be fitted outside the bathroom (above door etc) to feed the new lights in the bathroom, would this do?
people think that we take them for rides and that gear costs us 20p for a job load..!! Walk away from it,
RCD spur = ÂŁ25
cheap RCBO = ÂŁ13 with ÂŁ2.00 enclosure plus cable... probably cost same price, what suggests he will not want to pay for the RCD spur either...!
its a notify job as well...! let some cowboy do what he wants and chase bigger fish mate!!
RCD spur = ÂŁ25
Would you need rcd on lv downlights
regs say RCD in bathroom ( zoned areas )
Regulation 701.411.3.3 now requires that additional protection shall be provided for all circuits of the location by the use of one or more RCDs having the characteristics specified in Regulation 415.1.1. This is a significant change. Previously (601-09-02), only
fixed current using equipment (other than electric showers) located in zone 1 required 30mA RCD protection and current using equipment (other than fixed current using equipment – such as a washing machine, if suitable for use in a bathroom, connected through a fused connection unit) in zone 3 required 30mA RCD protection. Regulation 701.411.3.3 means that all circuits, including lighting, electric showers, heated towel rails, etc., will require RCD protection, not exceeding 30 mA.
All parts of the location not just the zones.
So id be ok just to spur the new lights and leave the rest of the light circuit as is?
Still would test all the light circuit out etc but only my work in bathroom would be rcd from the spur and comply ?
ta
Not so, the feed from the consumer unit to your lights in the bathroom will all so require RCD protection, if they are less than 50 mm buried into the fabric of the building.
Assuming you have all so confirmed bonding ECT.
Regards KJ
Regards KJ
They are existing and not new keith. Only thing i will be changing is the bathroom light to 4 down lights.
Hi there, You have to conform to, to days regs if you are installing any new equipment eg bathroom lights, you have to bring the circuit you are working on and the bonding at the Origen up to today’s standards.
Regards KJ
Hi there, When you alter an existing circuit, you have to confirm the circuit can supply the addition load, and subsequent fault currents, there for you have to test the hole circuit, and confirm it complies to current regs,
Regards KJ
Reply to Bathroom lights RCD etc in the Australia area at ElectriciansForums.net
Ok I’ll try this when I’m down
ok cheers for the help lads
