Battery Drills | Page 2 | on ElectriciansForums
Discuss Battery Drills in the Electrical Tools and Products area at ElectriciansForums.net
I'm a makita man, bhp451. The good thing about the makita 18v is the vast range of other tools on the same battery platform. The bad points were the early makita batteries had a few problems if not recharged regularly but has improved (and so hass their customer response to this).
If you're going to spend more check out milwaukee. Did have a look at the new bosch cool battery range and if you look into their brushless tech marketing it is impressive, makita do brushless too but I have not tried either of these as a user so can't validate their hype,.
If you want to spend less then look at the Ryobi One range.
do not buy the 453 that is on offer at wickes
it is vastly underpowerd
it has half the torque off the bhp451
Reply to Battery Drills in the Electrical Tools and Products area at ElectriciansForums.net
Yet another vote for the biggest and the littlest. I use the big SDS solely for chasing (you still need it if you have a chaser as it doesn't get...
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
