batterys in series | on ElectriciansForums
Discuss batterys in series in the Australia area at ElectriciansForums.net
dogfood
hi every one
just a quick one if i connect 2 x 12v battery's in series to get a 24v supply what happens to the Ah of my batteries?
thanks in advance
Mike
thanks guys
thats what i thought (im the apprentice) but i asked an electrical engineer at work and he said having them in series would give the sum of the voltage and the Ah. it just didn't fit for me so i though i would ask.
thanks again
Nice one. I still find the water flow analogy best, still only one path for current to flow so stays same but doubling potential difference.... Parallel gives two psths so greater flow....but same PD as they're side by side not one after tuther... If u see wot i mean
You must be a plumber then. Proper sparks think in sparks' terms! ;)
Reply to batterys in series in the Australia area at ElectriciansForums.net
24v lead acid chargers are commonly used in the medical/nursing/care home world. Most patient hoists are 24v lead acid. Also powered wheelchairs...
Hi, advice please if this would be fine and not cause issues with either the batteries or the inverter. I have read that LifePo4 batteries aren't...
