baumatic extractor hood faulty | on ElectriciansForums
Discuss baumatic extractor hood faulty in the Australia area at ElectriciansForums.net
my daughter just bought a kitchen from a kitchen company thats closing down.
they included a baumatic BT066ME extractor hood but nothing happens when i turn it on?
theres power going through to the connector blocks then nowhere else,
on the switches are extra terminals but i dont want to move wires about and damage the unit.
is it possible the power light is a type of fuse?
if yes what amp will it be
Easy way to tell is if it'swired with a live on one side and a neutral on the other it's not a fuse.A fuse will always have a live in and a live out.
when you say there is power to it, how are you measuring that. of using a voltstick or ( perish the thought ) a neon driver, it could be trhat the neutral is not present.
so, if you have a L and N, and the neon doesn't light. then the fault has to be before the neon ( assuming the neon itself is good.). suspect connection/s, possible screw clamped on insulation.
I'm not trying to insult your intelligence so please don't take this the wrong way. Did you check the installation manual? There's often packing pieces and sometimes they tape or otherwise disable the safety switch if it has one.
Reply to baumatic extractor hood faulty in the Australia area at ElectriciansForums.net
