Bending 90 in 20mm or25mm conduit | on ElectriciansForums
Discuss Bending 90 in 20mm or25mm conduit in the Talk Electrician area at ElectriciansForums.net
sam80
Please can some one help me please haven't done steel conduit for a while. What's the best way to get a 90 bend at the right length 1st time???
expensive! tbh i concentrate on getting the bend right, making the length over sized then offer up to wall or whatever and trim and thread. much easier than spending time calculating distance from back of bend to some mark on the former.
I’m with telectrix on that one, the time spent trying to save a few inches of tube is not time well spent.
I don’t care how good you are you will be a bit over length (if your lucky), or short and then it’s a case of do you save it and hope you can find a use for it or scrap it!
There is a calculation using the center line radius of the bend, but as stated above by the time the calculations have been made the job would have been done. Your time is more important than a few off cuts. Although i suppose its good to know especially when you get to some more elaborate bends.
Regards Chris
Take a fixed length, say it 300 mm from fitting to a corner. Mark the 300 mm on the conduit, place the conduit parallel in the former, take a square and line the mark on the conduit up with the back edge of the former and bend. This will give you a length from a fixed point to back of the bend of 300 mm.
once or twice and youl have it bang on, but as said its a time thing and would be good if you could get few lengths and practice, then its easy.
last time i done conduit work it was on a curved wall and at a height, so had to be formed on ground, NIGHTMARE!!! TOOK AGES
Use a set square to line up your measured mark with the front of the former and you will get a perfect measured 90 bend. Ofcourse if your using a full length of conduit you can't do as it hits the floor when bending so take 50mm off the measure if using 20mm tube and put the tube in vice other way round and line up again and bend.
Sent from my HTC Desire using Tapatalk
It would take too many words to accurately explain. I was not being flippant when I said get some conduit and practice. Use some off cuts or something. Basically you can either use a set square off the edge of the former. or you can use the etched marks. The rest you'll have to work out. You'll have it nailed after about 5-10 bends. Remember you can bend up as well as down. When bending up you'll have to use the set square.
If you don't have a set square use a small cutting if conduit held vertically in the former against the mark where the back of the bend will be and judge the right angle of the two conduits with your eye, then bend. This is how I've done it for years and without boasting I get a perfect bend every time, bang on to the mark. It's a lot simpler and you don't need to rely on having a set square to hand. And as the boys have said, if the conduit is too long for normal bending then turn the dog up side down and bend upwards.
put ur conduit in the bottom of the former and push it in as far as you can until ur index finger gets stuck in the former. Then bend the conduit up(making sure it is ur measure you are bending up and not the excess) and that should ensure you get the correct size first time. That is your size to the back of the bend
Reply to Bending 90 in 20mm or25mm conduit in the Talk Electrician area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
On the 4th day God created this sun:
