Bending tails etc. | Page 3 | on ElectriciansForums
Discuss Bending tails etc. in the UK Electrical Forum area at ElectriciansForums.net
kingeri
Yorkshire
Been sorting through my toolbag and getting ready for tomorrow's job. For years I've had a cable bending tool to put a nice clean bend in tails etc., but it seems to have been nicked at some point. :( Any recommendations for a replacement? Can't find anything exactly like the one I had.
Yep thats true as well, I'm serious when I say we would bend a pipe around a tree trunk, serious.
I believe you.
I once read a book about W. O. Bentley - of Bentley car fame - and in it is described making the exhaust pipes for the cars (1920's era).
The exhaust pipes were made from copper, which they stuffed full of sand, then heated up to red hot and ran outside with them where there was a tree with a forked branch which was used to bent the pipe to the required shape.
We would bend the pipe around the appropriate tree, if a tight bend was needed a young tree was picked, a large radius a bigger tree, laughable now but it did happen years ago, the bends on a conduit bender were considered too tight back then for some types of cabling haha, ridiculous but honestly true.
youre not seriously trying to pass this bull-crap off as fact are you MDJ ?
its the 1st of jan not the 1st of april.
I've had some tricky big armoureds to do last year. It was a pain because they glanced into the bottom of isolator and the cores were all crossed over and there wasn't much room.
I could have done with some sort of bending device so I made do with some lumps of wood that I'd drilled holes in.
It did help with the extra leverage I needed but unfortunately it dug into the insulation in a few places and I ended up heat shrinking it to hide the damage.
The cables were 95mils and 120mils so they were a bit unforgiving.
Reply to Bending tails etc. in the UK Electrical Forum area at ElectriciansForums.net
J
Purpose of vent under sink? There are bad smells that come from my sink drain when I run water. On inspecting (undoing) the U-bend trap, there is...
Jimmy8127
J
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
