R
Rosco22
Well with 300 down lights bout 160 power points and 2 double garages inc 3 phase commandos for machinery and a games room, gym and underground heating pump system the 3 phases are justified.
That list just came off the top of my head. My point was there will be a much higher load on the ground floor than the other floors which will most likely just use lighting, occasionally appliances such as hairdryers and televisions, maybe heated towel rails, whereas the ground floor will have all the entertainment stuff, which is unlikely to be used at the same time as the stuff in the bedrooms.TBH, with this list, do you even need 3ph anyway????? A premium billed expense when all you've got is probably coped with happily on an 80A single once you've done some diversity calcs.
