Best place to buy certificates | Page 3 | on ElectriciansForums
Discuss Best place to buy certificates in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
i did make some in Spread sheet format so you can type in your bits you want
MINOR
https://www.dropbox.com/s/m8yfkh9zk33ro1l/Form5.xls?dl=0
Do check over it and point out if I've made any errors.
I do try and copy them to the letter but i do miss out things
Testing Results
https://www.dropbox.com/s/25p109u5075yaq0/Form4.xls?dl=0
https://www.dropbox.com/s/ng28q65hbbzxc4l/Form3A.xls?dl=0
https://www.dropbox.com/s/tm9cst6gdh73i8x/Form3B.xls?dl=0
still got the EICR to do by the looks of it
I'm going by the advice on the law change that happened this month...
Scottish Landlords | Electrical Safety First
And, what I meant was dealing with testing and inspection initially, I'll need to see how the client take up is and assess whether it's enough to keep me going or if I need to broaden my horizons.
If you're dong inspections for landlords now, are you having to do PAT testing for them or is the requirement generally just EICR? According to that advice, PAT tests must be done at the same time as the EICR.
Thanks for for the info, I knew about the changes just not the scheme part, looks like they've managed to wangle more business surprise surprise, looks like I'll have to join one then, was going to join Stroma, made the enquiries, but was asked for £280 before I had spoken to anyone or even asked what the requirements were so I told them where to go. I will be going with the cheapest though as it's all a bit of a farce!
Yeah I PAT whatever needs doing, generally there isn't much as landlords don't tend to leave many items for use apart from washing machines and sometimes fridge freezers.
I wouldn't try and stick to just T&I mate, advertise for it but I would think you'd need to do a bit of everything to earn a crust, EICR's take up about 10-20% of my work, plus the variety is better, you'll crack up just doing the one thing lol!
Reply to Best place to buy certificates in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Pedantic Pirate Pounces Persistently! As my English teacher often said "Always avoid alliteration"
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
