Best practice guide 4 update | on ElectriciansForums
Discuss Best practice guide 4 update in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
newfutile
Nearly Esteemed
Supporter
hemel hempstead
I have emailed electrical safety first regarding the BPG4 update : i have just received the reply
Hi,
It should be published in the next couple of weeks – it is in artwork and out for comment with the signatories.
Regards,
Enquiries
Bets in on what code for Type A RCDs (I'm guessing C3 for now at worst, maybe C2 if fault protection by RCD), and AFDDs where they are mandated (likely C3 for now too I would expect)
You must mean type AC rcds? It should be C2 unless purely resistive loads present, but BPG4 have always been easy coders i think so most likely a C3 same with Arc Fault Detection Device in high risk residential building
I still think C3, as there would have to have at least 2 faults present for there to be danger: enough DC leakage to blind the RCD, and an earth fault. I'll bet codebreakers will have it as a C2 though.
Reply to Best practice guide 4 update in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
T
TTA Hosting Further Webinar Introducing 2024 British Standard Update Next Week - From TTA TTA Hosting Further Webinar Introducing 2024 British...
The Tile Association
T
Best Electrical Courses I endeavour to create a "best electrical courses" thread for 2025 (so training courses that did well during 2024 are the...
