Best RCBO consumer unit | Page 3 | on ElectriciansForums
Discuss Best RCBO consumer unit in the Electrical Tools and Products area at ElectriciansForums.net
another ting to consider is this..... your electrician will have his preferences and for the boards he usually installs will have spare RCBOs, and have a rapport with suppliers as if anything goes wrong, replacements will be readily available. that's related to my post ~28
Understood. I’m sure if I ask him to install something he knows nothing about then he might challenge it.
Again thanks for everybody’s help I think I have enough to short list.
I've fitted Hager, Wylex and BG boards (all RCBOs). BG I will not do again, mostly due to critical alignment of the modules with the lid, the DIN rail is just too flexible so unless your incoming tails are tensioned just right in the main switch (not pushing it down too much, and not pulling it up too much) there's always difficulty closing the lid. It sounds a trivial thing, but its enough to make me say "never again!"
Hager boards are good, the quirkiness with the square knockouts notwithstanding. I tend to find all the action is on the right hand side (particularly with SPD fitted) leaving some bits cramped, other bits with loads of space. But very happy with the quality - rigid DIN rail, not problem fitting the lid, earth/neutral bars not made of cheese etc. Can easily insert/remove MCBs/RCBOs without affecting the busbar. Type A RCBOs, and can get bare boards supplied with a type 2 SPD.
I've recently started fitting Wylex boards (the "new look" NMX14S) with SPD, these are very nice, with good space inside; again, good rigid DIN rail. The only design niggle I don't like is you have to knock the (round) knockouts out from the inside outwards. This is fine when swapping the board, but if you're later adding to a populated board, it turns a simple job of adding another circuit (without going through the rear knockout) into a more complicated job (unless I'm missing a trick? maybe hitting them sideways with a screwdriver?). Like the SBS boards (which I've not used), the Wylex have switched neutral (type A) RCBOs - if used on a TT earthing system, it's a no-brainer. They're a tiny bit dearer than the equivalent Hager boards (from my wholesaler) but they're growing on me, after being a Hager fan for a while.
Hope that helps :)
Electricians are a bit like economists ... ask 10 for opinions and you’ll probably get 8 different answers
My view on customers supplying parts .... my day rate rises and I charge extra for every minute wasted if all the parts aren’t correct.
When I do a CU change, I supply the kit AND I take my spares box with me too so I can adapt or change what is required depending on what I find inside the existing unit .... without leaving site and wasting time or money
I can understand OP's view point here. He's after an installation of a particular product, be it a CU, washing machine, tv, mobile phone, artificial grass etc etc. Wants advice on the best product, dull as it is with a consumer unit. Why can't he canvas views here, without the 'ask your electrician' responce etc etc.
Personally I give my customers the option of SBS or SBS, so easy to fit, I have only ever had one failure which was duff from the box and I have fitted hundreds of the things.
If cost isn't a option then my preference is Wylex .. However I've recently been installing Lewden RCBO boards with surge protection as the cost has been considerably cheaper than Hager & Wylex.
Lewden offer A type RCBOs but they are not included in their populated boards. I don't think MK offer A type RCBOs yet they also don't offer surge protection devices.
Cheers. Appreciate the comment, it’s always sad when forums have people commenting like that. If I was asking about doing notifiable work without being competent then I would expect that sort of thing, but this is different.
I think I do have what I need and it’s useful to speak to people that deal with this day in day out. The people I work with only use Schneider acti9 for commercial building services and this is not within my price range.
I’ll go back through the thread tonight and use the info for when I do get the work done so thanks to everybody
If you are on a budget try contactum. For any customers on a tight budget who want a full rcbo board I always use them around 9-12 quid per rcbo depending on where you go and consumer units feel good quality. Always been surprised at the quality of them
Late to the party as ever....
OP, if you’re still looking for opinions, I have to thank you for mentioning SBS. I’d never heard of them before. I’ve been banging on for a while that a neutral bus bar adjacent to the line bus bar is surely the way forward. So good for you. And if I were your electrician, I’d be quite happy for you to supply whatever equipment you choose: your gaff, your rules (and your risk, but you’re smart enough to have worked that out already).
FWIW I’ve been quite happily installing Lewden pre-populated RCBO consumer units for some time now, and they’re fine. If budget allowed I’d probably use Hager or Schneider or Wylex or Crabtree (or SBS) but generally it doesn’t. The reduced-height DP A type devices offered by some of the above offer distinct advantages not offered by the Lewden too. I tend to steer clear of MK nowadays as the price:quality ratio has plummeted IMO.
I’ll be interested to know what you choose in the end.
Good luck!!!!
So, your chosen electricians can’t be up to much then? Instead of using their advice/knowledge you would rather do your own research, which basically consists of coming on here and asking other electricians..
Hi Charlie, yet another rude comment from you, once I have read your lame reply I will be leaving this Forum. You are an oxygen thief.
Also late in,
I only install Rcbo boards if I'm supplying materials.
OP you've had lots of good advice, although I did skip some posts. I'd like more clients to provide materials, one less thing to worry about. If you're still wanting Rcbo on a budget:
BG: not fitted many as I don't like the brand but they've installed ok.
Contactum: fitted more and I like these, not had a problem.
Live: are a bargain but bring a holesaw. I use wiska t&e glands for cable entry and the access for these is below par imo. Be prepared for a struggle aligning front panel and fixing screws, you pays your money etc...
Where budget is slim these boards have been acceptable to me.
Also late in,
I’ve been installed Lewden RCBO for years with only 1 RCBO failure. I’ve fitted lots of their 19 way boards too.
I recently installed a 10 way in a remote games room in a garden with batten & board onto block work. I mounted the back onto the block, meaning just the lid is protruding, which looks pretty good.
Reply to Best RCBO consumer unit in the Electrical Tools and Products area at ElectriciansForums.net
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
